Lamps by Post - For all your lighting needs
Thread Tools
Old 1 Week Ago   #1
Sweden
OBD Diagnostics
OBD...
Iīm searhing for the best combo of Hardware & Software, for on board diag, on the Punto Evo Abarth -2010. CANtieCAR is a bit expensive, so i have decided to go for the ELM327 with adapter and MES software (MultiEcuScan) instead.
PURPOSE...
My main purpose is to be able to reset / rewrite the service milage, but also to acces all other systems including the CAN. So ELM327 usb + Adapter "A3" (Yellow) + MES should be the most cost efficient setup.
Now to my main enquiry...
I now that there is an ELM327 BT interface aswell, that alows me to use Android with different apps like Torque for example. But what i donīt know is if / how the ELM Bluetooth version works when having to use adapters. As i belive that the extra adapter is a must for my car, when using MES software.
BEST OPTION?
So i guess i might have to go for Another software, that doesnīt require the x-tra adapters. Then i can use both Android + PC with BT!
But is there a software that is cmbatable or better than MES for Fiat / Alfa ??
Thankīs
Alfawizz is offline Reply With Quote Quote
Old 1 Week Ago   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: OBD Diagnostics
Quote Originally Posted by Alfawizz View Post
is there a software that is better than MES for Fiat / Alfa ??
Short answer, no. MES does it all. Yes it's a pain being tied in with cables but that's the price you pay for a fully functioning OBD software.
Eklipze3k is offline Reply With Quote Quote
Old 1 Week Ago   #3
Sweden
Re: OBD Diagnostics
Quote Originally Posted by Eklipze3k View Post
Eklipze3k : I was afraid someone would confirm this..
Thankīs
Old 1 Week Ago   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: OBD Diagnostics
OBD...
PURPOSE...
BEST OPTION?
Thankīs
Bluetooth and other wireless interfaces should not be used for critical functions like setting parameters, updating odometers or accessing airbag modules. You don't want a random bit of radio interference corrupting the data on those. Effects could range from excessive mileage indication (you can't turn it back) to an airbag in the face!.
Use the USB ELM and MES. Torque is very generic and gives wrong parameter readings on many Fiat.
Also wireless does not remove the need for adaptors, Only the multiplexed interfaces (like the one with MES Pro) do that.
Robert G8RPI.
Likes Eklipze3k liked this post
g8rpi is offline Reply With Quote Quote
Old 1 Week Ago   #5
Sweden
Re: OBD Diagnostics
Quote Originally Posted by g8rpi View Post
Robert G8RPI.
Robert G8RPI: Well i Think that pretty much decides it then! An ELM327 USB with the A3 Yellow adapter + MES with license, it will have to be.
The CANtieCAR is way to expensive, just to get rid of one adapter.
Thankīs #RobertG8RPI & #Eklipze3k for your answers.
Old 1 Week Ago   #6
Sweden
Re: OBD Diagnostics
Found a bundle that i think will suit me nicely. https://www.gendan.co.uk/product_FESCAN.html
Apperently there is another, more upgraded interface
(The OBD Link SX USB Diagnostic Interface) that works with the ELM protocol, so that will hopefully do...
Si if i donīt find the "original" ELM327 usb and adapter cheaper somewhere, íīll probably go with this pakage.
Any comments??
Thread Tools
(T) OBD diagnostics philboo Panda (2012+) 40 05-09-2016 14:38
2013 Panda OBD diagnostics philboo Tech Talk 11 27-04-2016 07:28
(T) OBD Scanner / Live diagnostics synchro Bravo / Brava 35 15-01-2016 11:04
(T) OBD? Diagnostics? Superdad Stilo 1 17-05-2011 15:27
jtd's and obd diagnostics stilosporting Lets Talk FIAT 19 04-03-2008 19:04
