OBD...
I´m searhing for the best combo of Hardware & Software, for on board diag, on the Punto Evo Abarth -2010. CANtieCAR is a bit expensive, so i have decided to go for the ELM327 with adapter and MES software (MultiEcuScan) instead.
PURPOSE...
My main purpose is to be able to reset / rewrite the service milage, but also to acces all other systems including the CAN. So ELM327 usb + Adapter "A3" (Yellow) + MES should be the most cost efficient setup.
Now to my main enquiry...
I now that there is an ELM327 BT interface aswell, that alows me to use Android with different apps like Torque for example. But what i don´t know is if / how the ELM Bluetooth version works when having to use adapters. As i belive that the extra adapter is a must for my car, when using MES software.
BEST OPTION?
So i guess i might have to go for Another software, that doesn´t require the x-tra adapters. Then i can use both Android + PC with BT!
But is there a software that is cmbatable or better than MES for Fiat / Alfa ??
Thank´s
PURPOSE...
BEST OPTION?
Thank´s
