Lamps by Post - For all your lighting needs
Thread Tools
Old 22-04-2017   #1
Germany
Replacing the heat exchanger (heating)
after 7 years of not changing the coolant liquid in my APE (199 model type), there is finally a leak in the heat exchanger. I noticed it some days ago when the sweet swell of Paraflu first hit me
Actually, I thought in modern cars there would be no need for replacing that fluid more often than every 10 years.
The problem appeared the very next day of a very fast autobahn run (6th gear full revs for half an hour chasing a VW Scirocco R). This was unusual for the car and me, as I normally never drive that fast, revving it only to 3500-4500 rpm. Maybe the water pump created a lot of pressure, making micro fissures in the already slightly oxidized heating matrix?
Now, how do I get the heat exchanger out? I did this on my Bravo almost a decade ago, now I have to do it again :-( But I had a manual at the time. Now with the electronic online stuff, it's become more difficult to do things, as there is no more manual available.
Where do I have to look for fittings and bolts, and what do I have to take off? The entire dashboard? Is it glued on?
And should I do the thermostat (the one keeping the cooling liquid at a fixed temperature) too?
Zardo
my car and I have problems beyond the dreams of analysts...
get us a shrink, please !
Zardo is offline Reply With Quote Quote
Old 23-04-2017   #2
Germany
Re: Replacing the heat exchanger (heating)
I actually just found a Haynes workshop manual for Punto Evo (not Abarth) published in 2015 which I ordered hoping it will cover this topic.
Any advice is still welcome
Old 23-04-2017   #3
varesecrazy has donated!
Quote Originally Posted by Zardo View Post
I assume you are describing the cabin heater "MATRIX",
http://www.fiatforum.com/grande-punt...ease-help.html
the basic dash layout is probably unchanged from the 2006 cars,
have look on ePER for good parts diagrams also
Charlie - 2012 punto
Likes Zardo liked this post
Old 23-04-2017   #4
Germany
Hello, thanks, yes I am talking about the heating matrix in the cabin.
I found some other post of a guy who had the problem with a Barchetta...
http://www.fiatforum.com/barchetta/4...ml#post4142810
But I also found a post where the smell was caused by a leaky water pump.
When I close the vents and switch the climate control off (only permitting cabin air to recirculate), there is almost no smell.
Also, having the heating on full blast, there is initially a heavy odor which seems to quickly become less prounounced as if maximally venting the heating matrix would dry it, making the smell first become strong as it dries and then make it go away...
So does not seem to be the pump, or why would the smell become less?
It could theoretically also be a leak/crack on the main heat exchanger (the one up front cooling the engine), but this should be visual and there would be a drop in the level of coolant liquid - I have to check that again.
Old 23-04-2017   #5
Germany
I'll also start posting stuff here which I find might be helpfull for this project.
Airbag removal:
Steering wheel removal:
Instruments removal:
Cabin filter removal:
and
Thermostat change:
Or I could spare all the trouble and simply pour two egg-whites in it:
Thread Tools
(T) Coolant leak from heat exchanger? woj Grande Punto 5 21-03-2017 13:32
(T) Heat exchanger in cabin sime Stilo 6 23-02-2017 09:30
(T) 1.6 sporting heat exchanger crack Andy86 Punto Evo 6 22-04-2016 18:14
(T) 02 ducatto heat exchanger (1.9TDI) rangitira Ducato 3 10-10-2012 18:59
Heat Exchanger Unit lowser1 Doblo 5 30-04-2012 22:26
