Technical Grande punto mods,and 300hp project
Laccarazy
Hi guys, I'm modifying my big grande punto 1.4 t-jet, kit the turbo td04,390cc, airtek ic, full ported heads, NA cams from 1.4 N / A 100cv, motor block to 72.5, with forged internal, painted red wrinkle,
Bilsteins pss b14, everything is new has not yet been tested, I am currently mounting my internals, and I wanted to share with you so I can hear your opinions, I will soon post photos of the process,
At the moment I have everything clear, but I need to know if the cams that I bought are plug and play or need some mod? I have the ref number of them, in case this can help,
Thank you for reading(y)
Correct me if I am wrong, but aren't 390 ccm injectors a bit too little for 300 hp?
Yes friend,, when all is ready ...the car will be run in a dynojet, for 300hp whit 390cc injectors and fpr 3 bar,, will be enought
You will need a higher flow fuel pump as well.
Maybe a 4 bar fuel pressure regulator.
Hi mate. I'm using t-jet 200hp. I'm looking for anothere cams then stock and wonna try cams from atmo 1.4 16v. What do you think about it?
Would the cams from a panda 100hp fit? And what kind of price would I be looking at to get my engine forged? At the mo I’m running 252hp-273.5nm with td04 set up would love to get over the 300+ barrier so any info on the forged internals would be much appreciated ??
