Thread Tools
Old 27-11-2016   #1
Greece
Gearbox problem
Good evening.
I would like to buy ball bearings,And I don't know what is.Can you help me?
I'll attach pictures with my own bearings.Let me know ASAP.Thanks so much for your time.Click image for larger version
ID:	173946Click image for larger version
ID:	173947Click image for larger version
ID:	173948Click image for larger version
ID:	173949Click image for larger version
ID:	173950Click image for larger version
ID:	173951Click image for larger version
ID:	173952Click image for larger version
ID:	173953Click image for larger version
ID:	173954Click image for larger version
ID:	173955Click image for larger version
ID:	173956Click image for larger version
djb52 is offline Reply With Quote Quote
Old 28-11-2016   #2
Ireland
Re: Gearbox problem
All those old bearings and seals will have numbers on them that will be unique to the size, go to a bearing shop with all of them.
digger58 is offline Reply With Quote Quote
Old 29-11-2016   #3
Greece
Re: Gearbox problem
I havent remove the axles yet and I can not see the codes of the bearings
Old 30-11-2016   #4
Ireland
Re: Gearbox problem
Which bearings do you need? The pictures show removed bearings!
Old 01-12-2016   #5
Greece
Re: Gearbox problem
2 x Differential Bearings NP537150/NP050487
2 x Top Mainshaft Bearings NP854792/NP430273
1 x Top Input Shaft Bearing NP797735/NP430273
2 x Bottom Mainshaft Bearings NP238750/NP929800
1 x Front Input Shaft 25mm Bearing NP259742/NP378917
1 x Front Input Seal Corteco OEM 24,5x41x6 mm
2 x Differential Seals Corteco OEM
Old 01-12-2016   #6
Ireland
Re: Gearbox problem
You say in your first post "I'll attach pictures with my own bearings.Let me know ASAP.Thanks so much for your time"
If these are your own bearings in the pictures then you have the numbers, even the inner and outer bearing housings are there, take them to a bearing supplier and you will get them. If you are going to replace the diff bearings you will have to remove them anyway.
Thread Tools
(T) gearbox problem wilshaw14 Punto (Mk2/2b) 22 08-04-2011 18:24
(T) gearbox problem.. help shyster Stilo 6 26-07-2009 09:58
(T) Six gearbox problem..... FraEos Cinquecento / Seicento 5 05-11-2008 19:41
(G) Gearbox problem MXH Scudo 1 19-07-2007 21:33
HELP! Gearbox problem... terry FIAT Boo Archives 2 18-04-2001 11:21
