Thread Tools
Old 01-05-2016   #1
SteveTjet has donated!
Random plug.....
Name:	ImageUploadedByFIAT Forum1462097265.011221.jpg
Hi all. I was having a clean and decided to lift the plastic that surrounds the hand brake. To my shock I found a plug that has no obvious connection as far as I can see. The wire heads underneath the plastic around the gear stick. Can any of you owners have a look at yours. See if you have the same loose plug.
The plastic surround just pulls off.
Regards
SteveTjet is offline Reply With Quote Quote
Old 01-05-2016   #2
Greece
Re: Random plug.....
Electric/heated seat controls connector?
(Although now that I think of it that connector has more cables)
cmosfxx is offline Reply With Quote Quote
Thread Tools
(T) Random front brakes smelling with hot rear brakes sticking on, random loss of engine iangray100 500 10 23-06-2015 18:31
Cinquecento HELP!!sump plug and plug sholding sleeve broken. dazza121 Members Motors 11 19-07-2012 18:48
(T) Gearbox oil change; drain plug & fill plug? combwork Multipla 3 03-07-2009 09:50
(G) have you seen a thing you plug in to cig lighter and has plug on other end fletcher11 Punto (Mk2/2b) 3 20-02-2008 13:16
Random Crash? Not so Random! Trancendental Computing 2 22-02-2007 16:12
