Technical Abarth 500 creaking noise (vid inside)
Pistolpete1
As per title guys. Car is on 1000 miles. Any ideas?
[ame]https://youtu.be/KJsz13P1TRA[/ame]
Your car is stationary so that creaking must from something that is moving and the primary culprit would, I think, be in the belt area. Try making a cardboard tube and listen from one end while you move it around the engine. Any spot for the noise found?:confused:
