Bartvandebroek
- Jan 29, 2016
- 17
- 5
The 900T Amigo in the Alps. ???
I have a completely overhauled GBS engine (from a 850 sport/spider - 54 hp vs 37 hp original), my experiences so far (our Amigo is fully loaded with 2 adults and 3 children. Also a 250 kg luggage carrier):
- yes you must install/leave the original low gearing diff. It's attractive to use a long diff from the sport/spider, but in the mountains you mostly drive in 2nd or 3th... on the highway the Amigo is happily revving and cruises 95 km/h easily.
- no serious heat problems occured, but you must have a good water pump, original fan, new radiator and all(!) the baffles installed. Also pay attention to ignition timing and don't set the carb to lean. I installed a water temp sensor with gauge from a 900E. Nevertheless the watertemp almost reaches the red zone on a steep / long way up. Today it was about 33 degrees outside.
- my engine has a compression ratio of about 10.5 to 1. Uphill when going strong sometimes the engine slightly knocks. It was all over with BP 102 Ultimate. No normal fuel in the mountains.
