Thread Tools
Old 10-09-2011   #1
phate316 has donated!
fiat 900t master cylinder
does anyone know where i can get a set of seals for the dual circuit brake master cylinder for my wifes lill fiat 900t, i cant afford to shell out 300 plus vat for a new master cylinder, does anyone have a fiat 900t there breaking that i can buy the master cylinder
thanks
tim
phate316 is offline Reply With Quote Quote
Old 10-09-2011   #2
Re: fiat 900t master cylinder
Are you on Discs/Drums or Drums/Drums?
The Scuderia Obsoleto blog:
http://spannerdude.wordpress.com
spannerdude is offline Reply With Quote Quote
Old 15-09-2011   #3
Hey spannerdude, ive got drum/drum its a benditalia dual circuit just cant get the rear brakes to bleed, front ones hold up fine, is there any special way that they need bleeding eg back to front, ive even read somewhere that you have ti spring the pedal back after each pedal push
Old 20-09-2011   #4
There shouldn't be anything unusual about the way they bleed. Mine hasn't got a rear brake compensator in the circuit that could cause an obstruction so I assume yours hasn't either? Some times if the flexi's are badly perished on the inside they can act like a one way valve but if neither side bleeds it's probably not that. I concur with your initial diagnosis
On the bright side, these guys list the master cylinder at a much more realistic price:
http://www.brakeparts.co.uk/
Thread Tools
Hi from Brighton! Fiat 900E van - need brake master cylinder paulypilot Newbie Central 0 27-03-2009 19:31
(T) Master Cylinder? fingers99 Cinquecento / Seicento 5 12-01-2008 13:44
(G) Fiat master cylinder, it's serious! unogirl45 Panda (Classic) 13 10-10-2006 18:17
