Thread Tools
Old 15-05-2017   #1
USA
Oil leak in Spark plug well
My fiat was missfiring and the code read ignition coil failure. I changed all the my spark plugs and ignition coils. well a few months later the same issue resurfaces. I take a look at my spark plugs and it appears that the one on the far right has something at the bottom of it. I extract the spark plug and a black seal/gasket comes out with the plug. I shine a light into the hole and there is oil inside. Has anyone replaced that gasket? Thanks for any advice. Kori
Hurricanekori is offline Reply With Quote Quote
Old 15-05-2017   #2
It's always more involved
John202020 has donated!
Re: Oil leak in Spark plug well
Is it possible that the "gasket" was the sealing washer from a previous spark plug? If so it should not be there. You don't mean oil in the actual cylinder bore do you, rather just at the seat of the plug.
John202020 is offline Reply With Quote Quote
Old 15-05-2017   #3
There shouldn't be oil in the spark plug recess. If there's oil there it has either trickled down from a leaking rocker cover gasket, or has been blown up from the piston due oil finding it's way into that piston bore..
If the spark plug seat/thread is damaged on that particular cylinder it will allow gases to escape - collect and 'bake hard' around the base of the plug - and form that 'gasket' you mentioned. If the seat - the thread which holds the plug is damaged (usually caused by overtightening a plug) a helicoil insert can be fitted.
An oiled plug/seat can cause a misfire.
However, there should be no oil inside the cylinder. If that plug is becoming 'oiled up' .. there's oil finding way onto the plug from within the cylinder, that suggests a piston ring problem. Oil is finding its way past the piston rings..
It's unlikely that worn valve stem seals or worn valve guides would allow much oil to find its way into the combustion chamber. Worn stem seals/guides are usually characterised by a cloud of blue smoke at start up from cold due to a dribble of oil having found its way into the combustion chamber whilst the car has been standing overnight.
Your misfire is probably caused by the carbon/oil build up at the seat of the spark plug. You need to find out where the oil is coming from.
Any half decent workshop would be able to give you an opinion within a couple of minutes. It's maybe worthwhile asking ...
glenn2602 is offline Reply With Quote Quote
Old 17-05-2017   #4
varesecrazy has donated!
Quote Originally Posted by Hurricanekori View Post
Hi Kori, and welcome to FF,
I believe the US market get a 1400 cc motor, the UK gets a 1242cc
so there are potential differences in spark plug,
I'm not familiar with a sparkplug with any type of black seal..,
they are generally built with a captive thin metal washer,
more old fashioned ones use a taper to seal,
Charlie
Thread Tools
(T) Oil in spark plug/oil leak??? carlh Punto (Mk2/2b) 22 05-08-2014 00:10
(T) oil in spark plug hole! thedigger Punto (Mk2/2b) 7 18-05-2009 14:47
(G) oil in spark plug Guybrush Punto (Mk2/2b) 3 25-07-2007 10:17
Spark Plug Covered In Oil Kristian FIAT Boo Archives 3 19-03-2006 09:28
(T) oil on spark plug smelluel55sx Punto (Mk2/2b) 1 07-12-2004 19:33
