Thread Tools
Old 25-02-2017   #1
Canada
wet floor
i have a 2013 fiat 500 cabriolet and the whole floor area is soaking wet, what could be causing this, PLEASE HELP
badabing is offline Reply With Quote Quote
Old 25-02-2017   #2
Moderator
Re: wet floor
Three main possibilities:
1. There is a leak somewhere which is allowing water from outside to get inside the car. On a hardtop, the windscreen glass and the area around the rear bumper attacment points are the two most likely areas to check, but on a ragtop, there are many more possibilities. The key feature in all of these is that it is more noticeable after rain.
2. The A/C drain is blocked, allowing condensate from the air conditioning unit to collect in the cabin.
3. A pipe has split in the windscreen washer circuit, most likely the one to the rear screen.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 25-02-2017   #3
varesecrazy has donated!
Re: wet floor
Quote Originally Posted by badabing View Post
hi,
use some white paper towel to soak some..,
does it have colour/ smell..??
rainwater = clear ,
condensate = clear
coolant = colour AND smell / odour
screenwash fluid = (probably)..colour and small
have a look ,
let us know,
Charlie
Thanks jrkitching thanked for this post
Likes jrkitching liked this post
Old 25-02-2017   #4
Moderator
Re: wet floor
Quote Originally Posted by varesecrazy View Post
Well spotted; that's a fourth possible cause - a leak in the coolant circuit somewhere in the passenger compartment, most likely the heater matrix or its pipe connections. Not common but by no means unheard of.
Probably the most expensive to fix of the possible causes (getting access to the heater box is a nightmare job on the 500), so fingers crossed for the OP that it isn't this.
Old 25-02-2017   #5
It's always more involved
John202020 has donated!
Re: wet floor
Might be a stupid question but has the car been subject to extreme rain recently?
Is it wetter in one area more than the rest? anything in the boot area, are there any leaves chocking the drains under the windscreen/under the bonnet?
have you cycled the roof to ensure its properly closed ?
30 years of Honda Accords, now Mazda 6 and a Fiat 500
John202020 is offline Reply With Quote Quote
Old 25-02-2017   #6
Re: wet floor
Close the roof sorry couldn't resist that
typecastboy is offline Reply With Quote Quote
Thread Tools
(T) wet floor astra2000 Punto (Mk2/2b) 14 03-03-2014 10:43
(G) wet front passenger floor (left floor) dave Idea 5 10-02-2014 13:40
(G) Wet Floor gotch26 Punto (Mk2/2b) 10 09-03-2011 17:50
(T) Wet floor? Visorfett Panda 8 05-08-2008 19:35
(G) HELP!!! Wet floor! fordie Ulysse 7 10-10-2006 20:27
