Thread Tools
Old 26-12-2016   #1
57 Lounge 500
altonwoods has donated!
USA
Best mods for 500/1.4
I was considering upgrading my O2 sensors and was curious about any other relatively simple stuff I could do to improve overall performance. I've already installed an Ingen intake I really like but that's all. LOVE MY500!!! Any ideas? '16 Lounge
altonwoods is offline Reply With Quote Quote
Old 26-12-2016   #2
UFI
500 TwinAir Plus
UFI's Avatar
UFI has donated!
Australia
Re: Best mods for 500/1.4
If you've got the 57 Lounge edition ditching those wheels for lighter ones would be the first thing to do. They might look cool, but you'd get the same effect and a much greater performance/ economy / even handling on a set of steelies with chrome hub caps and trim rings.
Smaller/ lighter wheels & tyres are overall the best thing I've done, in time I'll get proper light weight forged alloys, but mine's a Sport so it doesn't look right on excessively 'retro' wheels. On a Pop or Lounge I'd stick with chrome hub caps.
If it's a manual look at the TWM shifter, second best mod I've done.
Thanks Tommy boy thanked for this post
UFI is offline Reply With Quote Quote
Old 27-12-2016   #3
Netherlands
Quote Originally Posted by altonwoods View Post
Interesting. What's the benefit?
If I write something stupid, it's probably because English isn't my native language!
AGH1965 is offline Reply With Quote Quote
Old 27-12-2016   #4
It's always more involved
John202020 has donated!
Quote Originally Posted by AGH1965 View Post
There should be none,,bar perhaps cleaner running?
John202020 is offline Reply With Quote Quote
Old 27-12-2016   #5
57 Lounge 500
USA
Thanks UFI! That's a great suggestion, one that I'm sure I'll act on at some point perhaps when I wear some of the rubber off these new tires!
Old 27-12-2016   #6
57 Lounge 500
USA
The perceived benefit of changing out my O2 sensors has to do with somehow helping the motor operate more efficiently. I'm no mechanic but I was wondering if the sensors detect unburned fuel in the exhaust and relay that info to the brain that might adjust it somehow? I've seen a few upper/lower sensors on part sites and just assumed based on their high cost that they must be superior in some way!?!
Old 28-12-2016   #7
Moderator
Can't see how you'd get any performance gain from changing a lambda sensor unless the existing one is faulty. A simple emissions test will quickly identify if the sensor is working properly (it's part of the annual test in the UK); if the readings are within limits, then there's nothing to be gained in performance or economy by changing it. If it's out of limits, it'll likely trigger the EML light anyhow.
Also you won't get any gain in performance from modifying the intake except when you're operating at full throttle.
What may help (not so much with performance but with improving cold starting and running) is to fit iridium spark plugs - the original Fiat fit parts are rubbish. Probably the easiest, cheapest and most worthwhile mechanical mod you can make.
Likes altonwoods, typecastboy liked this post
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 28-12-2016   #8
Quote Originally Posted by jrkitching View Post
That's what happened with mine. It had jerky acceleration which was worse when the engine was cold. After taking advice on here I changed the top sensor for a used one as well as the plugs and the car now runs like new. I had a hint it might have been as the o2 measurement on the mot emissions test was right at the limit.
Likes altonwoods liked this post
typecastboy is online now Reply With Quote Quote
Old 29-12-2016   #9
57 Lounge 500
USA
I like the irridium plug idea! found these, NGK’s DCPR7E-N-10 whattaya think? http://www.partsgeek.com/catalog/201...park_plug.html
Old 31-12-2016   #10
+1 on the smaller lighter wheels - if of course you don't love the ones you have. Also it opens up a whole world of choices potentially.
I went the other way, got heavier, considerably wider wheels, and you really do notice a difference, but I won't be parting with them any time soon! Street cred and all that.
pretty much amazing.
Ruining my Fiat 500 since 2011. Scenehunters.
Noxide is offline Reply With Quote Quote
Old 31-12-2016   #11
Moderator
NGK’s DCPR7E-N-10 is the standard OEM copper core plug for the 1.4 500.
They're rubbish.
NGK DCPR7EIX are the iridium equivalent to the OEM plugs.
Thread Tools
(S) personal touches and mods to your 500? MrTc 500 32 22-08-2016 21:48
500 1.2 sport mods Luigino007 Newbie Central 0 27-03-2012 18:16
(S) what mods have you done to your 500 slammed500 500 26 01-02-2009 21:17
500 quid to spend on mods L33TOM FIAT Boo Archives 1 20-01-2005 22:48
