All lithium batteries give a "longer charge life", i.e. most KWH over their life if charged/topped off... the deeper a lithium battery is discharged, the more it wears the battery.
i.e. for the same total watt hours consumed, the battery will have more "life" if it is discharged 1/2 way 1000 times (and charged of course) as compared to discharged fully 500 times.
You can find this info on any manufacturer's site that makes lithium ion batteries...
Greg
The laptops spend most of their lives connected to the charger via the mains, and the Garmin get charged as soon as I get home, the others get charged when they complain, but it's always to 100%.
It's better to use as much battery capacity as you can at the expense of longevity IMHO. To keep it at the optimum 80% ish, would seriously risk the EV convenience and range.
So where does the Tesla fit in?
Is it better to keep the 500e battery topped off of run it to near zero % charge before plugging it in?
Have a read of this and you will realise that the answer to your question is much more complicated than you may perhaps have first thought.
Much of this information is new to me and I was surprised to discover that the mean temperature of the place where the car is kept and used may be more significant in determining battery life that the number of times the battery is cycled. That said, I have for some time stored Li-ion batteries not in regular use in the 'fridge, charged to about 50% of capacity.
The key point to take away is that you might want to reconsider purchasing an electric vehicle if you live in a hot climate - most premature EV battery failures reported in the US have been in Arizona.
It's an expensive toy. The base model is around eight grand down, then over £1000/mo on a 4yr contract.
I can't see many of the folks who buy one being all that concerned about this sort of cost/benefit analysis. You're not going to finance this sort of purchase out of the fuel savings.
You'd think so but apparently a service on a Leaf costs $400Servicing will be cheap though which isn't to be scoffed at.
Where is this statement by the battery manufacturer that says do not charge over 80%?
