The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > 500
Old 22-08-2008   #1
Trader Rating: (0)
Croatia
Question Problem with lights
I have some strange problem with lights. I'll try to explain as best as possible.
My headlights (low beam) can't be turned off. I can move the switch on top of the left lever to "O" or to "lights" but headlights always stay on. This beam of light comes from the bulb which is positioned in the upper part. At the same time the little bulb situated in the lower part is turned on and is also always turned on. I guess those are position lights.
I can access "daylights" option in my menu, but nothing changes if I set it to "no" or to "yes" User manual explains that daylights are turned on if headlights are turned off. I can't turn my headlights off so maybe that's the reason why my daylights never turn on But I have another question: which bulb is supposed to emit the daylight? How many bulbs do you have in the lower part? I have two bulbs: one is for high beam, the other one is turned on (as I have already said - I think those are position lights). But where is the daylight bulb? My friend says that there should be another bulb
Can you send a close-up photo of your lights?
Did anyone have some problems of this type?
I went to my dealer this morning and they are not sure about the problem They said that they would try to get more information about it.
floating.point is offline
Old 23-08-2008   #2
white 500's Avatar
Trader Rating: (0)
Re: Problem with lights
the daylights are the lower ones in this unit there is 2 bulbs 1 is for the "full" beam the other is the daylights if you select "no" on the daylight's settings they should only come on with the main headlamps the top ones should illuminate and the lower ones go dim.
it could be a feature for the croatian market where the lamps are on all the time, if that's not the case then i think you may have a problem.
i'll take some photo's for you a.s.a.p
white 500 is offline
The following user says "Thank You!" to white 500 for this useful post:
floating.point (11-09-2008)
Old 11-09-2008   #3
Trader Rating: (0)
Croatia
Cool Re: Problem with lights
Suddenly it works. Does 500 have some self-repair function?
(T) Lights Problem andywebs Bravo / Brava 1 01-02-2008 10:02
(G) lights problem thebouncer Punto 2 12-09-2007 00:41
(T) Problem with Lights Help! oldskoolmk1unoturbo Uno 6 01-06-2007 01:42
(T) Problem with lights Bionic Punto Punto 4 16-06-2006 10:12
(T) Cinq Sporting Electrical Problem - Brake lights/rear lights namb Cinquecento / Seicento 3 20-02-2005 18:00
