| Air Con Problem?? I have had Bibi back for a couple of days and ever since the Air con seems to be playing up. They checked it while she was in and said it was a bit low, so topped it up. Well since then the car just seems different, theres a real noise coming form the bonnet like one of those ventilaters on casualty and the engine power seems to dip quite alot when the air con comes on and does this sort of jerky type thing, dont really know how to explain it properly. Is this normal and could it just be I never noticed it before or could there be a problem? I'm sure the dealers will think I'm neurotic if I go back
__________________ ![]() 'BIBI' ![]() 1.2 LOUNGE S 500 LUV | |||
| mad bad and very very old | Re: Air Con Problem?? The aircon is worked by a compressor under the bonnet. When activated it will drop the revs, but the ECU should sense it and bring it back up again. If it is really hot outside the compressor has a lot to do, so could be noisy. I have a diesel so don't notice it. Cheers PD
__________________ If it has pistons or tits, its going to be expensive. | ||
| The following user says "Thank You!" to rallycinq for this useful post: | ||
slimgimli (31-07-2008) | ||
| | #3 | ||
| Moderator | Re: Air Con Problem?? Sounds exactly like mine and all other small engined cars... the aircon makes a very noticable difference to the performance and I really hate that. I was hoping 100hp might overcome it, as my wifes 90hp Golfs performance is exactly the same with or without aircon on. Your underbonnet noise sounds normal too... have to say mine isnt that cool itself, again the Golf is better in that respect and its 13 years old!
__________________ 500 1.4 LOUNGE, Calypso Orange, vintage tan leather, 16" wheels, side strips, chrome mirrors, 500 mats. | ||
| The following user says "Thank You!" to nuovapanda for this useful post: | ||
| | #4 | ||
| Panda's with Gadget's | Re: Air Con Problem?? Might be worth having a look here as they're sort so the same car with different body pannels; http://www.fiatforum.com/panda-new/1...when-cold.html Jon.
__________________ Most Easterly Panda's - Panda'ing in East Anglia ![]() 5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL, 1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4If my post or someone else's has helped, say thank you using the Thanks Button \/ | ||
| The following user says "Thank You!" to Most Easterly Pandas for this useful post: | ||
slimgimli (03-08-2008) | ||
| | 850kd | Stilo | 3 | 28-07-2008 00:47 |
| | 850kd | Stilo | 0 | 25-07-2008 09:36 |
| | circ65 | Punto | 1 | 01-07-2008 22:21 |
| | Matt_C | Stilo | 7 | 30-04-2008 09:15 |
| air con problem | L(F/i/a/t/1.6)shA | Tempra | 0 | 14-07-2007 10:44 |
