looigi
Hi All,
After many enjoyable years smugly reading about the misfortune of others on this forum it has now happened to me.
Last week the Mrs was out in our newly acquired 1969 500L and managed to strip the splines on one of the driveshafts. Once I had finished making her feel thoroughly guilty for her obvious abuse of a classic piece of motoring history I ordered some new parts and got to it. No worries thought the brave man. Just pull the thing apart, fling some new bits at it and all will be sunshine and happiness again.
Then I thought that while the motor was out I would have a look at the thermostat flap the previous owner had welded in a fixed position and sort some of those annoying oil leaks. So I cleaned the outside of the motor, pulled the cowls off and cleaned it again. Then off came the sump. From the bottom the pistons looked new (I had been told the engine had been freshly rebuilt) the cam looked not too bad and all seemed in order. You could even still see the honing marks. Then I noticed the scuff marks on the #2 piston with matching marks on the bore. I was suspect of the quality of the rebuild anyway as many of the bolts on the outside were non standard and loose. At least one was held in with silicone!
Don't you find swearing helps in times of stress?
Questions for those that know.....
What is involved in fitting a 650cc kit?
Is the performance improvement worth it?
I have 650cc barrels, just need some pistons.... can I use the 500cc head?
I am guessing I will need a 650cc head gasket?
Is it worth upping the compression ratio?
Do I need to fiddle with the carb?
Many thank you's in advance
Chris
Chris
