timgarman
Established member
Hi Folks
The engine is out on my 66-F whilst I get the gearbox reconditioned. Time to fix that oil leak that was dripping (slowly) from the flywheel cover.
When we took the flywheel off there was no obvious oil coming from the centre shaft. But some traces of oil from the two plugs on the left (see photo).
What are these called? I've been calling them crankshaft plugs.
I believe new ones just tap in place. Is there a trick to removing them?
And I see there are aluminium ones available and it's suggested you weld these in place. Are there stainless steel plugs available that you can tap into place with some sealant around?
I've been in touch with Van der Laan and they don't stock them. Anyone know where to get these?
Thanks in advance.
Tim
Thanks in advance.
Tim
