I have direct experience that the hard working valve-gear on the 500 can debilitate the engine through wear, and obviously there is plenty of scope for ancillary components to deteriorate over time. But now I am looking at my third stripped-down engine which appears to have no significant crankshaft or bore wear.
I could have expected that from the first, 499cc engine, which I knew had done only 32,000 miles. The second 650cc engine was an unknown quantity which looked OK internally, so was re-assembled with new rings, shells etc. and without any measurements being taken. This third 594cc engine, with no history, has negligible wear after measurement so can be safely rebuilt without expensive machining.
It seems that these engines are unburstable. Does anyone have experience of real bad 'uns?
Over to you Toshi.
Over to you Toshi.
