It has been some time since I last posted on here...we have recently dusted off our fiat after a year or so in the garage, with just the odd run when weather allowed. Great to be back on the road in earnest, but not without the odd problem... noise from front wheels/ sooty plugs aside, biggest concern is a sneezing engine...
Under high revs, when I let off (both in gear and not) it is not unusual for an occasional sneeze from the engine bay, which results in a coating of oil over the tinware on the thermostat side of the bay. It is more likely to happen when the engine has warmed up, but can occasionally occur in the first few miles of a drive.
I have recently replaced the head with a refurbed unit that came with the car, and the sneezing persists. It seems as though oil is coming through the rear most hollow bolt - but I'm not 100pc certain of its or origination.
Compression is fine, but does that completely rule out rings? Current oil is Halfords classic and I may try 10w60 (better for high temp engines?) - changing oil would also allow me to check for ring debris in the sump - but otherwise I'm at a loss. I would be very grateful for any pointers/ diagnosis suggestions, before I reluctantly open up the bottom of the engine.
I have a 650 engine, with alloy sump and rocker cover, fzd carb and 123 ignition. Oil level is half way between min/max. Spark plugs are new and NGK BPR7HIX - previous plugs (BPR7HS) were black with soot. Have since leaned out mixture and will keep an eye on new plugs - my thoughts are that the sooty plugs is unrelated to the sneezing..
