Hi
Luigi is our 1965 500F S1 who, due to work and house renovation, has been off the road for the best part of 5yrs. Sorry!
However, as a result, he does now have a nice new dry garage and we are working on getting him back on the road.
We have replaced the ignition bits and carburettor and rebuilt the starter and dynamo so he now runs better than he has ever done.
New master cylinder has been fitted and this has resulted in having to replace the associated brake pipes. Just got the front-rear pipe to do and then bleed the system.
Hinge pins and drive shaft boots after that and we should be ready for the mot. Wiper motor also rebuilt and new mechanism fitted (where we discovered differences between S1 and S2!)
Sorting electrical issues is made intersting as his wiring loom was sprayed the same colour as the rest of him. As a result the cause of every electrical issue is the red wire!
We are also collecting parts together for a full restoration.
Being an S1, Luigi has 8 bolt door hinges rather than the later 4 bolt hinge doors. Is it just the outer hinge bracket that is different between the two door types? Can we just swap the outer hinge brackets over for a direct fit?
Anthony, Lucie & G
Anthony, Lucie & G
