Thread Tools
Old 17-07-2017   #1
Denmark
Alighnment,camber,caster when changing to 155/65/13
Hello everybody!
Is there enybody that have information about what to do, when changing from original 12" rims to 13" fittet with 155/65? I mean the alighnment, camber & caster.
I suspect, that if you ceep the original one, the car will perform otherwise than originally optaint from fiatīs owners manual.
I have a 1970f abarth replica, that i just got 4 weeks ago. It is not my first one. My first one was original fittet wheels.
The previus owner has fittet it whit other springs and dampers i can tell, but i donīt know if he did the alighnment part.
Thanks a lot.
Q
Big Q is offline Reply With Quote Quote
Old 17-07-2017   #2
Re: Alighnment,camber,caster when changing to 155/65/13
I have 165/55/13 tyres on my '695' replica---I have kept 'castor angle' the same (9 deg. +/- 1 degree) as this is practically impossible to change--the spring mountings and the wishbone-to-body studs are set to this angle. Camber, if the car is lowered, (as mine is) set to 1/2 degree NEGATIVE--i.e. the wheels lean IN at the top (you often have to modify the wishbones to achieve this). Toe-in--set as per factory--0-2mm toe-in.
the hobbler is offline Reply With Quote Quote
Old 18-07-2017   #3
Denmark
Hello!
Thanks you very much.
Q
Thread Tools
(T) Camber(front) and camber/toe(rear) on Scudo 07- pella1 Scudo 0 20-08-2016 08:07
(T) Front wheel caster adjustment sungoa2010 Grande Punto 0 08-12-2010 17:06
green gp sporting today at 4.50 Donny(caster) Steely Spotted / Was It You? 1 12-03-2008 20:54
(T) Caster, Camber and Toe Trancendental Tipo (Classic) 5 18-08-2007 14:55
Caster Angle Nigel FIAT Boo Archives 0 19-03-2002 13:17
