Thread Tools
Old 2 Weeks Ago   #1
Australia
Condenser relocation
Hi all.
I'm thinking of relocating the condenser from the distributor to somewhere else closer at the coil and connecting it directly to secondary terminals at the coil (-) where the low tension wire is.
As current follows the path of least resistance I'm thinking this shouldn't be a problem and should protect the condenser from the hot engine heat.
Can anyone tell me if they have tried this?
OO==/////==OO
124CS, 500F, GRANDE PUNTO, BRAVO T-JET
124spiderman is offline Reply With Quote Quote
Old 1 Week Ago   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: Condenser relocation
The condenser is there to absorb voltage spikes at the contact breaker points, so should be fitted as close as possible to the points. That's why they are fitted in, or on the side of, the distributor.
Likes 124spiderman liked this post
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 1.6 Ignition Coils (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 1 Week Ago   #3
Best money I spent on all my classics is to fit electronic ignition. It can be hidden so as to make it look standard . You then don't have the problem of adjusting the points and worrying about condenser failing and it is a cheap fix. Bryan
phoenix1 is offline Reply With Quote Quote
Old 1 Week Ago   #4
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by Davren View Post
The contact arc contains high frequency alternating current components so it is the inductance of the lead that matters not the resistance. For a lead over an inch or two long to be effective a common rule of thumb is that it has to be a flat copper strap or braid with a width equal to at least a fifth of it's length. So a 10" lead would have to be 2 inches wide. Easier and more effective to have it close.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 1 Week Ago   #5
Bleeding Knuckles has donated!
Spiderman, leave the condenser where it is and buy the best replacement (most expensive - you get what you pay for) you can afford, you will find the better items last longer.
Ian.
Likes fiat500 liked this post
Si dice in Sicilia non c'e nulla di piu pericoloso di una Donna con fucile da caccia.
Abarth - Piccola ma Wicked
Bleeding Knuckles is offline Reply With Quote Quote
Old 1 Week Ago   #6
In support of Ian's (Bleeding Knuckles) comment, if you wish to retain points and condenser, get one of the "Swiftune Competition" condensers (part number SW-IG-CC). They were developed for the classic racing car competitors, where due to the rules, the original ignition system has to be retained--even GT40s have to retain their points ignition. Prior to fitting a 'hall effect' electronic ignition on my (well tuned) 126 engine, I fitted one of these condensers--never had a moment of problem. You fit them in the same position as the original condenser (possibly using a slightly longer bolt) utilising the 'P' clip supplied with the condenser, and put the end of the earth lead between the 2 parts of the 'P' clip. Fit the best, once, and forget!
the hobbler is offline Reply With Quote Quote
Old 1 Week Ago   #7
Patinated Peter
fiat500's Avatar
fiat500 has donated!
It may not be a wise thing to do but on this page there is a condenser listed as being suited to fitment on the coil. .
https://www.fiat500vdlaan.nl/en/webs...goryID=31#4203
fiat500 is offline Reply With Quote Quote
Old 1 Week Ago   #8
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by fiat500 View Post
Well as they say, it's better for the condenser (capacitor). The inductance of the lead means the capacitor will not see the high level currents, and it will last longer, but it also stops it doing its main function.
Robert G8RPI.
Thread Tools
Temporay Relocation! Edinburgh TallTom Leisure Lounge 11 30-04-2013 23:42
(T) battery relocation edvaldez Cinquecento / Seicento 3 05-02-2012 16:17
(T) Ecu relocation Stormwatch Stilo 3 13-06-2011 19:08
(G) battery relocation pinkbay Punto (Mk2/2b) 2 16-07-2010 19:20
(T) Battery Relocation Todger182 Cinquecento / Seicento 2 22-02-2010 12:21
