AndrewRL
Member
Sorry i do have another question
At the weekend I finished the front brakes/wheels (although a drive will tell if I got the hub nuts correct!) and was tackling the rears. One wheel was OK (although the brake shoes are even more of a b***er to get on than at the front ).
On the other wheel I could not budge any of the four drum/hub bolts. With the wheel off and the handbrake on, the amount of force applied via a long bar still turned the wheel. With the wheel back on and the car on the ground the bolts are accessible but only with a spanner (with less leverage). I have been dousing the bolts in WD40 but still without a sign of movement :bang:
Any of your useful hints or suggestions?
