I just changed the oil in my 500R and noticed that after draining it and cleaning out the centrifugal filter, I hit close to the "max mark on the dipstick after only 1.5 liters of oil. I even ran the engine for about 5 minutes and then let it sit for about 30 minutes before checking it again. I'm 99% sure the oil capacity is 2.5 liters, and can't imagine an entire liter stayed in the engine after draining it. Can someone tell me if I'm reading my dipstick correctly, and that the line just before the word max is indeed the max oil mark? I'm assuming the other line farther up the stick doesn't have anything to do with the oil level. I drew a red line at the current oil level after 1.5 liters.
