the hobbler
Distinguished member
- Jul 25, 2012
- 4,078
- 1,013
Prior to removing the fuel tank (before I took the car to the body-shop) I drained it completely AND ran the carb dry, mainly so that there was no fuel left in the system to bugger it up--it was at the body-shop for the thick end of 5 months. When it came to restarting the car, more than a few 'anglo-saxon' words were uttered because I just could NOT pull fuel through. In the end I used a electric tyre air-pump with the nozzle in the filler-neck of the tank 'sealed' with a rag I held in place round the nozzle and with the fuel pipe disconnected at the INPUT side of the fuel pump, gently pressurised the tank to blow fuel through. As soon as fuel came out of the pipe, stopped the pump, and quickly refitted the supply pipe at the fuel pump----cranked the engine over for a bit and it burst into life--phew! Another option (which I hesitate to mention) is that old standby--'Easystart' A good squirt of that may just get the engine running long enough to pull fuel through.
Looking at your picture of the engine cover, Fiat used to fit a small, square heat-proof shield (used to be asbestos)on the inside of the cover to protect it (and the paint) from the heat of the rear exhaust--I would recommend that you fit one (not that difficult to make--most probably cheaper, and definitely quicker, than ordering one from Europe.
