Thread Tools
Old 15-06-2017   #1
Bleeding Knuckles has donated!
Disc Brake Mod??
Greetings All, The subject of Disc Brake Mod's to the 500 has been covered multiple numbers of times on the forum, but I thought I would cover what has been done to my car
I have been greasing the front legs today and decided to investigate the slightly 'different' mod to my brakes while the wheels are off, I have also noticed that the dual grease nipples on the nearside leg are on the rear side and the offside leg has them on the front?? No idea why
The first pic shows the complete brake and caliper, the eagle eyes will notice that the outside of the caliper housing has been ground away and I assume that this is for wheel proximity clearance.
I have determined that the Caliper at least is a fiat item by part number and belongs to the 124,128,131,X1/9 family. This is a single piston sliding caliper with the piston being 48mm. The second pic shows two spacers fitted of 4.7mm each, likewise on the other side (wheel location?). Removal of the caliper and pads is simple. Pic three shows the Brake carrier, this is bolted to an adaptor plate that uses the bolt locations for a drum brake back plate. The last pic shows the adaptor plate and a late 126 (77-on) hub. The brake disc is only 200mm in diameter which is perplexing because the family size used is normally 227mm Any ideas folks?? I have found that the nearside disc is very slightly warped and causes a little squeak when the brakes are applied at low speed, not yet decided if I can live with it or go for an upgrade including braided steel pipes. I have added a pic of the brake caliper too.
I'll continue with the pipe change later.
Ian.
ID:	181520   Click image for larger version
ID:	181522   Click image for larger version
Si dice in Sicilia non c'e nulla di piu pericoloso di una Donna con fucile da caccia.
Abarth - Piccola ma Wicked
Bleeding Knuckles is offline Reply With Quote Quote
Old 15-06-2017   #2
Re: Disc Brake Mod??
they have been spun down to the size..
the smallest 4x98 rotor diameter is 227mm
you should see what some of the conversions in Italy do...
cut down calipers and pads as well...
Bigvtwin996 is offline Reply With Quote Quote
Old 15-06-2017   #3
Patinated Peter
fiat500's Avatar
fiat500 has donated!
Similar to my 900e discs that I photographed yesterday:
http://www.fiatforum.com/850t-900/44...sc-brakes.html
fiat500 is offline Reply With Quote Quote
Old 16-06-2017   #4
The stub axles are made with the grease nipples on one side so you end up with one pointing forward and one back. The discs will be 227 that have been machined down to that size. Many people do not realise that you cannot get replacements straight off the shelf. I have got two brand new sets of those calipers that I bought years ago when experimenting with conversions and ended up using Cinquecento calipers so they are still in their boxes.
Toshi 975 is offline Reply With Quote Quote
Old 16-06-2017   #5
Thanks for the replies, I have found some 200mm discs on-line, but am unsure if they will fit the hub - may have to do some accurate measuring I do know that there are a few mod kits that use a 215mm disc, so I shall have to check if the wheel will take them. Thanks for the offer Dave could you pm me a cost please.
Ian.
Old 16-06-2017   #6
Got two pairs of these callipers , new Fiat parts & not recon ones. Can post in UK for 75 all in.
Old 18-06-2017   #7
Quote Originally Posted by Toshi 975 View Post
Thanks Dave, I'll consider it.
Ian.
Old 18-06-2017   #8
I have got 5 sets of new Fiat 227mm discs that I had machined down to 210mm some years ago. That is the same size as the discs that are on the conversion you get from Ricambio for the 500.
Old 3 Weeks Ago   #9
I'm waking up this thread to council opinion from those members with disc brakes fitted on the front of their 500 I am looking to replace the pads on my Fiat X1/9 calipers as they are worn, but also because they display little initial bite. I really have to stomp on the pedal hard to get decent retardation - I appreciate that todays systems work better and I'm not wishing to get the same feel as modern brakes, I just want more bite from cold without having to pull a hamstring to achieve it. So, what material are you using on the rather light 500?? EBC, Ferodo, OEM, Brembo or what???
Ian.
Old 3 Weeks Ago   #10
The problem is Ian, practically all production cars (I do realise that certain 'small number 'sports cars do not use servos) use servos, so you get a strong brake operation with relatively low pedal pressure. With the 500, you have no servo, so to get pads to work you have to push hard. The answer might be to have a conversation with a pad supplier (somebody who knows what he is talking about) as it may be that in order to get good low-speed/cold brake operation you have to use a softer pad. Pad wear might be accelerated a bit, but as the car is so light, this may not be a much of a problem. I have a pair of Cinquecento calipers which I will be using when I fit discs on my 500 over the winter. It will be interesting to hear what pads you eventually go for and their performance.
the hobbler is offline Reply With Quote Quote
Old 3 Weeks Ago   #11
dragonwagon has donated!
With the 500 being so light at the front it may not really benefit from having a disc conversion as good initial bite may translate into premature lock up....anyone remember the early Lancia Montecarlo? Personally, I'll be looking to upgrade the drums to improve their performance, which when all is said and done will be quite sufficient to tame the fearsome 30ish bhp I have in mine !
dragonwagon is offline Reply With Quote Quote
Old 3 Weeks Ago   #12
Have a look at this post on the Fiat 500 owners club forum.
http://www.fiat500club.org.uk/clubch...php?f=1&t=7934
I recently replaced all the hydraulics and shoes on my 500F and was really disappointed with the lousy brakes. I ended up stretching the springs by 4mm and the brakes are now superb. Earlier in the summer at a car show, I had a chat with a retired Fiat mechanic who had worked on the cars when they were new. We chatted about the brakes and disc brake conversions. He said that he couldn't understand the point of fitting disc brakes as you'd no longer have the self servo action of the drum brakes and would need to apply more pressure on the pedal. I'm confident that my brakes are now more than capable of stopping a 30 bhp fiat.
Likes fiat500 liked this post
Hobo1960 is offline Reply With Quote Quote
Old 2 Weeks Ago   #13
Greetings, as part of the brake upgrade I am changing the brake pipes all round. I acquired a Bf goodridge 126 set of braided pipes from Mr E.bay very good quality at a price : and so far have fitted the front items. a simple enough job, but the goodridge pipes use a threaded fitting with a nut above and below the bodywork support, this is a 1000% better solution than the iffy push-on clip of the original pipes the whole fitting is tight, next the rear pipes .
Ian.
Old 2 Weeks Ago   #14
These are a great upgrade that i have fitted to all my classics over the years. Vastly superior pedal feel.
I fitted them to my track prepared 911 and it was worth 50 horsepower- such was the improvement.
AndrewHarvey is offline Reply With Quote Quote
Old 2 Weeks Ago   #15
Quote Originally Posted by AndrewHarvey View Post
Hi Andrew, yep I'm hoping for an improvement too and I'll change the pad material and see if the balance between the front and rear is good. With the weight at around 530kg (ish) I think the late (larger) 126 rear drums will stay standard. I'm looking at EBC pads as their range is extensive and I may increase the size of my rotors as there is room in the caliper and wheel - it will not be by much maybe 10mm, but enough to give the caliper piston and thus pad a good grip. I don't believe that my application requires drilled or ventilated rotors - I don't want to stand the car on it's nose
Ian.
Thread Tools
(T) Fiat Grande Punto brake warped brake disc and brake shudder PolyMathHR Grande Punto 9 18-12-2012 12:25
(G) brake disc help spampebs Bravo 3 14-04-2012 14:43
(T) brake disc bladecs_04 Grande Punto 12 05-06-2010 10:57
(Tu) Brake Disc's RobSport Grande Punto 9 26-09-2009 12:08
Brake Disc's Blakes FIAT Boo Archives 6 30-05-2005 17:36
