Greeting All, I have already seen a previous thread re the above and have noted the change from standard springs (220mm) lowered to 190mm. my question is this, do I need to fit different (new) shockers with the shorter spring?? I am finding that if I press-on with the car and try to corner at speed (50+) the dear old positive camber presents itself with varying degrees of tuck-under. After the first event I have grown more accustomed to these acrobatics, but it must look weird from behind I don't have any idea of my suspension being modified or not, all I can say is that the wheel/tyre combination is different and there are spacers fitted. Could I get away with just shorter springs to reduce the camber and not change the shockers???? The car will probably never be used fully laden. Thanks.
Ian.
Ian.
