General 4th GEAR
General 4th GEAR
phoenix1
Member
Blackpool
Hi guys. I have a 500 L with 650cc engine with syncro box.When driving around town I never get into 4th ,only it seems at about 35mph or it judders by being in to high a gear is this normal. I have standard 12 inch wheels.
Thanks Bryan
yep, mine is the same.
Its the change in ratio of the gears/diff.
But at least it gives you a little extra top speed
If the syncro box came from a 126 Bis then the ratio may be a little high for the engine power
It is also fitted with 126 engine so its probably down to wheel rim sze. It could also be that the 126 has the same sisues.
