66cabriolet
- May 2, 2017
- 11
- 2
Hey everyone, I have a 67 500 F model with an unusual fuel issue. Seems 'air' is getting into the line and bogging the fuel pump. I'm stumped after I 1) replaced the carburetor, 2) replaced the fuel pump, 3) checked the gas cap for air flow, works fine, 4) checked the sending unit, its a recent replacement and in very good condition, 5) checked inside the fuel tank, spotless clean like new inside, 6) replaced the entire fuel line from the tank to the pump and from the pump to the carb.
After all that I am still having an issue of air in the line. The car runs fine down the road but then suddenly without warning will start to 'buck' on and off like the engine has the hiccups. The only visible problem is always the same and that is air in the fuel line. Other things I did to the car were change the head gasket because the old one was bad and leaking, adjust the valves, replace the old distributor with an electronic unit, replace ignition wires and plugs. I'm at the point where I don't like driving the car any more. Any one have any ideas what this insanity is about? its just to simple of a system to be giving me this much trouble. BTW I also have several 66 cabriolets. Thanks. Bone from NY
