I just want to run this by all in case I am missing the obvious:
Set up
650 126 Engine
Pieburg Electric pump
Fuel Regulator now set to 2 psi
Car just being awoken from winter lay up. Ran OK then no joy. Possible owner contribtion as I removed the mechanical pump (previously left in situ) ran the car wthout a fuel regulator.
Regulator now fitted but Car wont start resulting major flooding of the cylinders.
Logic suggests that the float chambers are stuck open after lay up, but before I pull the carb as there anything else I should consider?
Peter
Set up
650 126 Engine
Peter
