- Mar 15, 2016
- 56
- 19
Good morning Fiat Forum
I am once again after a bit of advice. I am currently in the process of changing the drive shafts on my 500R and successfully managed to remove the engine and gearbox at the weekend (pretty chuffed with myself). After following a very useful step by step guild I have also managed to split the diff and remove the old, totally knackered, drive shafts All pretty straight-forward so far. Anyway, as I've got the gearbox out I thought i'd remove the inspection plate to have a look inside the box and instantly noticed that the little gear, which I believe is either 1st or reverse, seems pretty mangled. I also notice that there was quite a lot of metal particles in the bell housing and attached to the sump plug. As far as I can tell all the bearings look intact. I haven't driven the car for many miles yet but up to press I haven't had any noticeable gearbox issues e.g. no trouble selecting gears and she's not skipping out of gear. I suppose my questions are:
1. Am I right in thinking the gear is worn and shouldn't look like that?
2. If it is worn, how bad is it?
3. If it is bad what are my options for replacing?
4. Is this something an average DIY mechanic can do?
At the moment I'm thinking of just replacing the drive shafts, rebuilding everything, putting the engine back in the car and enjoying driving her throughout the summer. Basically, working on the principle, "If it ain't broken don't fix it!" However, if is totally knackered and there is an easy fix it would make sense to do it know while I've got everything in bits.
What do you guys think?
