Technical Valve Seat Recession 110 Engine With Unleaded
I had a slightly disappointing visit to the precision engine workshop.:(
I wanted a ball-park estimate for supplying and fitting hardened inserts, fitting new guides which I will supply and for lightly refacing the head. At around £250 it was a fair bit more than I expected and not really viable.
I'll look at exchanging the head for re-manufactured one.
in my opinion that work is £100 - £150....
My engine builder would happily undertake and post it back...
http://www.vulcanengines.com/
05-106 Brands Hatch Park, Scratchers Lane,
Fawkham, Kent, DA3 8PH.
Tel: 01474 874 689
steves a great chap......
Thanks Andrew, I'll follow that up. There's no rush; it would just have been nice to get on with it, It makes the one that nathanrobo was selling look even more of a bargain!
I must admit though, I'm always really mean when it comes to lashing out money for services rather than purchases.:rolleyes:
I think that eventually I will have the head rebuilt but for now, having spent a lot on the car lately and with a replacement engine burbling along fine, the pressure is off. But I wouldn't want that little 500 engine to become a rusty basket-case in mine or in someone else's garage. So I want to do a shortcut to get it going on the cheap(y).
I have a very rusty-looking 500 engine which was prevously referred to on this Forum as suitable to become a boat anchor:eek:. I have removed the head, which was surprisingly straightforward for such a piece of junk. The images are poor but the seats have a much narrower "land" than the faulty head. Damage to the seats amounts more to corrosion pits rather than wear, which seems to support the idea that the seats are more likely to be some kind of sintered or cast iron rather than a high-quality steel alloy. Although I think it has done 44,000 miles, the engine has been inactive for at least 35 years:eek:
MAL_4310[2] by Peter Thompson, on Flickr
With nothing to lose but a head gasket, a few seals and a set of valve springs, I'm going to tidy this head up and get my 500 engine going again. It has a good set of rockers to match and it will be an interesting exercise to compare the noise levels and performance with it reassembled.
I would prefer to wait until the engine is worn in all areas before tarting up the head in synch with having any other worn parts re-manufactured.
With all I have read and know and recent experiences, it is becoming very clear that the condition of the valve-gear on these engines is probably the most influential factor on its smooth and efficient running. When I fit the 500 back into the car next winter or if the 650 gives up:bang: I will research the best fuel additive and drive with greater restraint and do less continuous "high" speeds:rolleyes: than I did previously.
I like the new font for blind readers like me. I can almost read it without my reading glasses if I squint a bit!??
I was under the impression that cars with alloy heads can run on unleaded quite safely. It's the old English and American cars with cast iron heads that need valve inserts. Ask a VW expert. All Fiat - and Italian cars -have alloy cylinder heads and they have hardened valve seats otherwise they'd only last a mile or so before the heads disintegrated.
The Fiat 500 does have inserts but lasted almost 16,000 miles for me. Latterly I hammered it creating the perfect conditions for valve seat recession; guess what happened? :) The seats on mine weren't hard enough to cope with extended periods of hard use​ with unleaded. :(
I've been playing with the salvaged cylinder head to see what I can do with it. After a very brief grinding with very fine paste the valves and, to a lesser extent the seats, have come up superficially looking quite good; there are some big casting marks.
MAL_4814 by Peter Thompson, on Flickr
The head was probably laid up in good condition but there are corrosion pits on the seats which would need re-cutting or a detrimental amount of grinding in order to get rid of them. The spark-plug threads need repairing.
The valves are concave rather than at a straight edge on the 45 degree surface but sit nicely on the seats.
MAL_4810 by Peter Thompson, on Flickr
MAL_4812 by Peter Thompson, Getting close up I can see that number two of the exhaust valves is starting to go slightly out of shape on the edges. This is the same one that went faulty on the original head.
To summarise, this tells me to do things properly and get one of the heads overhauled but instead I'm putting in an order for gaskets and valve-springs to do a bit of bodging which from experience, could give me another 10 to 15 thousand miles of motoring. If I take it easy and use the optimum lead-replacement compound I might even go further. :D
I wonder how many 1,000's of miles were on those valve seat inserts before you clocked up 16,000 miles?
Back in the day (when the 500 was new), it wasn't unusual to have to do a decoke and top-end rebuild after 30,000 miles and a full engine rebuild after maybe 60,000 miles. This was despite oil changes every 3000 miles.
Times have moved on, better materials, tighter tolerances, better oils, resulting in engines typically lasting 150,000+ miles before needing a rebuild. But the parts available to rebuild a 500 engine now may be not much better than what was originally used when the 500 was new....
I'm thinking valve and valve seat material especially. It's fine to say that there's better, more long lasting, more resistant to valve seat recession materials available nowadays but the parts being supplied for the 500 may not be made from the latest and best materials. I remember valve made from Nimonic Steel being available back in the '70's but these were only available in certain sizes to suit engines that were populars with Tuners.
Re: your pic of the burned-out valve in the 1st post. Back in the day, it was common practice to reface the valves on a special grinding machine and re-cut the seats before lightly lapping-in with fine grinding paste. If too much material was removed from the valve sealing face, the edge of the valve was left excessively thin to cope with the heat from the exhaust gas. It might then distort and split and the subsequent searing heat of the exhaust gases escaping would erode away at the weak point ending up with a valve just like the one in your picture.
There was actually iirc a figure given for the minimum thickness of the edge of the valve after refacing. In your last post you show a valve which has a hollowed sealing face. I reckon that if this valve was refaced the old-fashioned way, the edge of the valve would then be too thin to last very long.
Like you, I too would simply lap-in the valves and reassemble to get some more miles covered and maybe rebuild a spare head properly at a later stage as time and funds permit. You might even come across another head or engine in great condition!
Re: Seat width. I'd agree that the seating contact line should be quite narrow on the inlet valves (Pencil line width as IanEmery has said) but I was taught to leave a wider contact face on the exhaust valves, maybe twice as wide, as this is how most of the heat is conducted away from the exhaust valve head. Some exhaust valves were hollow and contained sodium to try to keep the valve head from overheating (the sodium melted and flowed up and down moving heat away from the head).
Afaik modern practice is to cut the valve seats using a 3 angle cutter and use new valves. Some modern valves have a special coating on the sealing face which shouldn't be removed by lapping/grinding in.
Many people don't pay sufficient attention to the condition of the valve guides. On an overhead valve engine such as the 500, the action on the rocker arms opening the valves puts a side load on the valves, so the guide bore doesn't wear evenly, you need to check the valves for play in
2 planes. Any excessive clearance between valve stem and valve guide can allow oil to be drawn down and into the cylinders on the over-run, resulting in a puff of smoke when you go back on the throttle. Same as what can happen if valve stem oil seals, if fitted, are worn/ hardened/ cracked.
If up-grading the valves to one's made from a different material check
that the valve guide material is compatible. Iirc there's some combinations that can cause problems. Most guys in machine shops usually know their business inside -out, so ask for their recommendations first before booking in a job with your instructions on how things are to be done.
Al.
As usual, the wise words of experience from you Al F123C.:worship:
My engine has now done a total of 48,000 miles and obviously suffered a big hiccup before my ownership at 32,000. The other head comes off an engine at 44,000.
I remember that in the early '80s, all of the many 500s I owned seemed to have done around 35,000 miles at which point the engines worked fine but were quite tired and leaky. So you're correct that they can't achieve anything like the longevity of modern engines.
I have had a bit of speed-learning to do do in order to catch up a little with your knowledge on this, but there is evidence to support all that you say about valves, guides and seats.
Until forced to think about it I wasn't aware of the extreme forces at work in the valve gear, which is borne out when you see how shiny the contact faces of the rockers and shaft are when you dismantle them and clean them up.
I will certainly be giving this area much closer attention when I eventually rebuild an engine brand to new specifications. I now don't even think that the distinctive clatter of these engines is an inevitability if the valves and gear are detailed as they should be.
Peter,
Many thanks for your words of appreciation, you're too kind.
It always nice to feel that someone is listening to any little bits of info that I post. (especially if they agree with me :D).
I'm sure with your conscientious approach and careful research you'll end up with a great engine should you decide to rebuild one in the future. (y)
If you haven't already done so, you might check into engine 'blueprinting' techniques, some of which might be useful to you in any rebuild work.
Hope you're back on the road soon,
Al. :eek:
I've been motoring for a couple of weeks now in the previously prepared 650 engine. But although it's going well and is very frisky and great fun, I prefer the way the 500 engine and gearbox are better matched to the weight and geometry of the car.....the 650 has to be in third gear for too much of the time.(n)
In any case I've already proved to myself that having a spare engine in stock is very wise; so I should have this one sparking into life again very soon.
....and I will get into "blueprinting" and hope to prodce my best and most thorough (and expensive) rebuild ever with the 600cc version.
It's interesting as my original 500 engine that was swapped out about 20 years ago but got to 69,000 odd. In the end it became a more economical route to purchase a recon engine that was shipped in from Italy. Basically it had so many problems with it that you could hardly do up a bolt up without it threading. In those days parts were not as readily available to consider a rebuild. So it seems it actually did quite well to get to such a high mileage.
As Peter said you do see a lot of 500's around that seem to have reached mileage in the 30 or 40,000's. You also have to remember that a lot of these cars (when they were in daily use and not just one of our pleasures) would have reached those sort of miles on leaded petrol.
Judging by Peter's experience it would seem that the use of unleaded is going to have quite a detrimental effect on the valve seats and unleaded petrol is only going to make that worse. Obviously it would make sense to have harden seats installed if you are going to cover the sort of mileage Peter does. The rest of us pootling around, doing probably less than a thousand miles a year will probably be fine.
I'm going to start a Government petition:
"SAY NO TO POOTLING" :D:D:D
When will I see my first 500 on the road coming from the opposite direction on a normal day well away from any car-show or rally?:bang:
PS. I think you're being optimistic at a thousand miles.:D I reckon I've already done more miles than most since fitting the new engine.:)
Yeah but you are lucky where you live being fairly sparsely populated area. I just googled Nairn population and apparently it is about 12,000. My village is 4,500 but you go 10 miles north and you hit the London suburbs and the traffic that comes with it. It's just not as easy to use a Fiat 500 down south, other than the occasional weekend pootling.
I probably didn't go more than about 10 miles or so from my house today for work and must have hit 5 or 6 lots of temporary traffic lights. It's a nightmare at times!!!
You have a 1960's car with 1960's traffic by the sound of it.:D
Spoilt it by having a1950s driver...just.:D
I'm starting to think it would be better if I drove the car in a more stop/start part of the world. The gaps between towns around here do let you get up quite a good speed and whenever I start to get a continuous tone from the engine now I worry about all those hammering little valves.:eek:
I checked today and the valve gaps are perfect and with the strobe, the timing is spot-on with the standard distributor on tickover and advance. I daren't go beyond 50mph but there's a lot of throttle pedal not being used.:eek:
I'm off to Braemar tomorrow...about 90 miles each way. Now that is a perfect Fiat 500 652 drive...up and down and round and over hills most of the way; motorcyclists love it.
I don't think anyone else should abuse, ahem, be quite so hard on their car as me, but wherever I lived I would always feel the urge to use the 500 for any journey that didn't strictly need the modern car. eg. Sainsbury's, the post office, getting any DIY materials foldable or compressible or stickable through the roof from B&Q:D, taking bin-bags to the dump, etc. etc.
It makes me so happy driving the car :) and despite being a bit of a misanthropist, I really get a kick out of the fact that every day I definitely light up the faces of at least two or three people. The best ones are the blokes who just spin round on their heels and keep looking intil you're out of sight and the schoolkids who are all thumbs-up (y) and "Great car Mister!".
These little engines CAN do quite high mileage---when I had the problem with the distributor on my 500s engine (on the way up to Edinburgh from 'saaf lonnen') it already had 98,000 on it. Ann and I did 4-1/2 round trips to/from London/Edinburgh over an 18 month period---that's 400+ miles each way! (I will concede that the A1 45 years ago was a much nicer road to drive than it is these days--now it's practically another motorway). Mr Lampredi knew what he was doing when he designed the 110 engine.
These little engines CAN do quite high mileage. Mr Lampredi knew what he was doing when he designed the 110 engine.
I would be the last to disagree with you on that Tom.:D But even without the extra complication of unleaded petrol, I am in agreement with Al in that regular attention to the valves, unheard of in modern cars, was probably expected as a natural consequence of normal driving.
In comparison with modern motors, the natural rev-range of the 500 is quite high. With overhead-valves (also now largely superceded) clacking away at such a rate, as I keep saying, I think this is an unavoidable, early wear-point on the engine.
