Technical Clutch and Brake Pedal assembly
daniel170
I have a Fiat 500 1972.
Does anyone know if there is a spacer between the firewall and the brake and clutch pedal assembly to make room for the clutch cable lever to move freely?
Does anyone have a picture of the whole pedal assembly fixed in position to see the placement?
Thanks in advance,
Daniel
Here you go. No spacer just a gasket. There is a dimple in the bodywork which the clutch cable follows.
Thank you Paolo for the information and photos.
Does anyone have a picture of the gas pedal fixed in position as well?
Thanks again.
Thanks again for the photos.
It must be that I don't have the dimple on my replaced firewall.
What do you think is the best solution as I have already painted the car?
