Duffys Dad
Member
- Feb 19, 2011
- 99
- 86
I have a set of Early Fiat 126 wheels which I believe were fitted to the Fiat 500 R (not sold in the UK). They have a wider track and 135R12 tyres which I think fit the wheel arches better. However I wanted to fit the original Fiat 500 Hub caps on these wheels as i don't really like the look of the wheels and wanted the origional look.
I was wandering if anybody else had tried this? I was thinking of drilling a hole on the centre of the wheel and welding a nut onto the back inside face, but I'm worried about clearance on the front wheels where the bearing centre dome sticks out. Having offered up the hub cap to the wheel I can see that there is about a 5mm gap between the hub cap and the wheel at the centre hole, but not enough of a gap to weld a nut to the outside of the wheel. I wandering of it is possible or necessary to cut a hexagonal hole in the centre of the wheel and weld a nut part way into the wheel.
If anybody has had experience of this and could advise I would be most grateful.
Many Thanks
Many Thanks
