Greetings All, having just got my car back on the road and taking it out to reduce the 'running in' milage at every opportunity I was rather miffed the other day when I noticed that the engine has begun to run slightly 'off tune'
It starts well but on tickover when warm, just hunts and misses slightly from time to time. Rather than a nice smooth purr
Now, I run a Weber 30DGF on a low level alloy manifold that has always performed well - the plugs (NGK BPR7HS) show good clean colour, but the exhaust is slightly sooty
The colourtune shows a picture of nice even mixture at tick over with the addition of the odd flash of rich mixture in time with the hunting. It also indicates worn parts (diaphragm and metering needle/jet) the funny thing is that this must all be happening with only the primary choke open, with both chokes in operation the engine pulls well and runs if anything slightly lean as it pops back on overrun hence the clean colour on the plugs. I have a service kit for the carb and will change everything and try again, but I do wonder if the overall tune of the engine is in some way producing the symptoms, but the cam is not too wild - yet
I'm also sorting the upgrade to the carb department with a Solex C35PHH which seems to have just about the ideal choke/venturi combination with 35mm choke and 31mm venturi for this size of engine. It will also be a jump from the Weber 30 DGF with only 23mm venturi, I'll keep an update with pic's as I progress.
Ian.
Ian.
