Hello all! Greetings from Maine, USA, where my father and I are the proud owners of a new-to-us 1972 500L. Short story: Dad and mom had a 72 500L when they first met. Mom passed away last year and dad moved in with me a few weeks ago. I bought him the Fiat as a surprise - something to keep his rather forgetful mind occupied and give us something to do on the weekends.
The car does need a bit of work - it doesn't run now, but turns over - and neither my father nor I have a mechanical bone in our body. We do, however, have plenty of space and my wife is pretty forgiving...
I suspect we'd like to get her running and then be able to safely drive her in a 'spirited' manner - with a focus on being able to drive her rather than have a forever project.
I'm contemplating upgrading the motor while rebuilding, which would then mean that I'm upgrading the brakes, transmission, reworking the suspension a bit, probably some of the electrical system, etc.
So here's my question: The easiest avenue seems to be to buy a pre-built motor from a company like mrfiat in the USA. We'll wind up with about 40hp, a rebuilt trans (with syncros!), disk brakes front and back, and some other bits and bobs to keep us from killing ourselves.
A less easy avenue would be to order individual parts, get a pro to do all the prep work, and then build everything ourselves. I'm tempted to go this route because I've always wanted to learn, but don't know the slightest thing about what pistons or cam shaft I'd need, or, really, even what to say to the motor-prep-eria (Can you bore this 500cc engine out to 8 cylinders/6.5 liters? That'd be swell, thanks...). Rebuilding a trans looks even more complicated... Are there (very) step by step manuals for that sort of thing for cars this old? Is there a thread for "If you want a fast car but know nothing, order exactly these parts"?
Finally, I've seen a company in the UK that swaps Subaru 2.5l motors/trans/brakes into these, and 200hp sounds awfully tempting, along with much better parts availability. The downside, obviously, is that the mail-away option isn't much of a project.
To summarize, I guess I have 2 questions: 1) Can a mechanically inept doofus and his demented father really tackle this sort of project in a reasonable amount of time or would we be better off ordering rebuilt and starting our learning with 'here's how you take out the old one and put in the new one'? 2) Is 40 hp really enough, or is 40 hp what you can squeeze out of 2 cylinders and has therefore 'been enough' until a 200 hp swap became a possibility?
If it's worth anything, we have a (professionally maintained) newer Porsche that we take to the track often, so are used to driving a rear engine/rear drive car in a 'spirited manner'. 200hp in a small rear/rear car doesn't, per se, scare me. Perhaps it should??
Thanks in advance,
Fuzzy
Thanks in advance,
Fuzzy
