Strada Bianche
- Dec 30, 2016
- 35
- 12
Hello, friendly Fiat people, this is my second post regarding my rebuilt 650 engine for my 500F.
I am just fitting a 123 ignition unit (123/Fiat-2-R) with a question on the timing.
Several posts seem to indicate that the static advance needs to be set at 10 degrees (as if a manual distributer was installed), but the 123 instructions indicate that it is installed exactly at TDC / Compression Stroke?
I assumed that the unit automatically sets the advance itself from exactly TDC, but the instructions tell you to 'watch the position of the old distributer' which presumable being manual has had its static advance set.
Having only just got my head around the two different TDC's it would be sweet not to screw up! so any clarification would be greatly appreciated.
