My engine (original 499cc) is running better now that some loose electrics were discovered and the fuelling adjusted using a CO meter (idles at 1000rpm with exhaust CO of 3.5 is that ok?)
Compression measures at 80 in cylinder 1 and 90 in 2 but only on the final 5th or 6th turn. Is this acceptable or is it enough reason to inspect the valve seats - any opinions? We couldn't find exact information but my friend said he'd want 120 psi on a 4 cylinder mgb engine, presumably it would be less here though.
Thanks for any advice in advance,
David
David
