Well like Richard et al. I am determined to find a solution?
just to muddy the waters a bit more.
It seems that what everyone thinks is a ballast resistor installed in the bonnet near the headlights is actually a dim dip resistor for the headlights. "It is in fact a headlight resister found on many models of Fiat and Lancia of the late 1980s and early 1990s. For those of you who would disagree it's part number was 82428191 and description "headlight resister'. It was fitted to UK and Ireland spec vehicles." Of course it doesn't match up with the picture from the manual that Peter posted??
It's location would make sense to this being a fairly reasonable conclusion. See diagram below.
There are also some posts that suggests the following "The ballast resister is the wire itself that runs from the fuse box its not a component that bolts on.
Additional external ballast (wire) 1,70Ω +/-5%."
Also "Then, the powering of the coil does not depend on the fusebox. It goes straight from the battery (orange wire) through the ignition key (pale blue/black wire) to socket 28, (pale blue wire) to socket 40, (orange wire) to socket 48, then to the coil is the ballast resistor wire - the blue one".
These are from posts on the Club 126 forum taken from a Polish website, which is where a lot of 650cc engines come from.
Interesting!!!!!! I can't see how a resistive wire would dissipate the heat from the voltage drop. I assume there must be a resistor somewhere in situ?
Tony
