Hi guys. I can't see another connection ,could it be the terminal marked B+.
While I was looking for this I found ' Made in Poland ' on the plastic alternator
cover
Also does anyone know of an easy way to get the bottom channel and rubber insert
on the drivers door drop glasses.
Hi I have just started for the first time in the car and the red charging dash light does
not go out.I have checked and it is charging (13.5 v ) It is a 650cc engine with alternator.I thought I had followed the instructions on this forum ,but obviously must have made a mistake. Any thoughts ?
Has anyone an actual photo of an alternator wiring. (rather than a diagram ) I must have the warning light wire connected to the wrong terminal as it wont go out.When checking voltage at the alternator it is 12v from the dash light and 0v on the alternator an does not change when started.
