The spring stops the whole lot, including the pedal, from rattling. It also keeps the release bearing from repeatedly bouncing on the clutch....you need it.
Pull the lever at the gearbox as far as it will go towards the rear of the car...the direction that the spring would pull it in. You should feel the pedal being pulled upwards from the floor. Then slowly push it towards the front of the car until you feel definite resistance. It should need only a small amount of travel to achieve this. If the movement is significant, this equates to a lot of pedal travel before the clutch even starts to work, so slacken the small locknut on the cable and try to wind the larger one in the direction of the front of the car. This may be challenging if things are seized, but if you can keep going until there is just a small amount of free movement before the clutch lever reaches a resistance, you will have the clutch pedal roughly where it should be and it can be fine-tuned later; but at least then you may have some improvement.
Your images hadn't uploaded when I first replied but one of that gear linkage area and the part where the clutch cable is clamped to the gearbox would be useful.
