Greetings,
I have just started the fabrication of my oil cooler mount on the left side of the rear panel/crossmember. I'm satisfied that there will be sufficient airflow from under the car due to the shape of the protective apron under the alternator
(mine is low enough to perform as a scoop) and I'm sure that a simple 'lip' could be added to it to improve the airflow if required. I may also sort out some wire mesh if it looks like collecting the odd piece of debris. I've used a simple piece of mild steel box section and some small flat bar just to stand the cooler away from the left side engine lid prop on it's rubber bobbin mounts. There will also be two more bobbin mounts from the top fittings of the cooler to hold it steady and help absorb vibration. You will notice that the position of the thermostat is on the rear of the engine mount, there is sufficient room for piping to and from the pump and cooler. I'm using 1/2" BSP fittings as they are common, large enough not to restrict oil flow and M12 to 1/2 BSP fittings are available to fit to the engine casing. The actual piping will be bespoke, braided, short and neat. when I get my timing case/pump problem sorted I'll get back with more progress.
Ian.
Ian.
