What toe-in and camber angles are you going to set the front suspension? I have found that just a fraction of toe-in (factory is 0-2mm) is best--mine is 0.5mm; and a fraction of POSITIVE camber when the car is siting with nobody in it. I have set my (lowered spring) lowered suspension so that the bubble in the camber gauge is JUST nudging positive camber (car empty)---that way when it has people in it, the camber goes to JUST negative. Too much negative camber, and it will show up on tyre wear! You might also find that by lowering and changing camber from factory you will lose some of the 'self-centreing' action.
Alternatively, you could try and find enough bags of spuds etc. to put in the front to represent a couple of people---but you will be surprised as to how many bags you will need!
Hi Tom.
I had seen another post where you mentioned your set up so was going to dig that out once the car was back together.
A member of our club here has recently installed a wheel alignment hoist in a workshop that is small enough for Fiats so when the time comes we should be able th get it right.
