So, following the suggestions made in earlier postings I stripped out the seats and, after carefully lifting the rubber flooring, removed the various fittings which enabled me to follow the fuel hose through the centre tunnel. I had seen that the hose visible in the boot from the petrol tank had been replaced with a high grade modern rubber material and now could see that this was one piece from front to back so Im fairly sure there is no leakage from that. However, one thing I did discover is that where the hose goes out at the rear there is no grommet fitted. All the other control cables, brake pipe, etc have grommets but the largest, oval shaped one is missing and, after reading the postings about fuel leakage from the overflow on some carburettors, I wonder if this is the source of the fumes. I've searched the suppliers websites and found packs of grommets but haven't, so far, seen this grommet available separately. Has anyone any ideas of a supply I could try?
I'm thinking my next task should be to strip the carburettor down and try to ascertain why there is a little fuel coming out the overflow
Is it necessary, or advisable, to fit an overflow pipe and run this into a tee piece fitted in the supply line in a manner as discussed on the thread entitled "Blocking or re-routing the carburettor return line"?
All comments appreciated.
Ian
