5 51tinmin New member Joined Sep 1, 2014 Messages 18 Points 10 Jun 19, 2015 #1 hi everybody i am trying to find the correct tire pressures for the classic Fiat 500
stevehg Patron member Parked in the garage Joined Sep 22, 2010 Messages 780 Points 248 Location Cambridge Jun 19, 2015 #2 They are 16 psi front, 23 rear and 27 rear if fully loaded. The front, on paper, appears low but there is so little weight over the front axle. cheers, Steve
OP OP 5 51tinmin New member Joined Sep 1, 2014 Messages 18 Points 10 Jun 19, 2015 #3 Thanks of the info. the front seems so low.At the moment the front on my car must be up in the mid twenties.and the rear probably well over 30 will change to the recommended pressure.It must effect the handling of the car would you say.
