- Mar 18, 2015
- 121
- 38
Hey,
Out cruising (can you do anything else?) on Sat and after maybe 20 mins of driving the engine became noticably more noisy, rumbling.
On closer inspection it was coming from the dynamo. I took the belt off and ran the engine and no noise.
Now when I got the car 2 months back the belt was super lose and was whipping around with the engine running.
3 weeks back I took out 2 spacer washers to tighten it up whist still leaving over 1 cm of play.
It had been running great since.
When looking at the engine on sat the belt now seemed quite tight.
Once home I added 1 washer back in to add some slack. Started the engine and it sounded fine again and took it for a spin and it sounded fine.
But when you kill the ignition it sounds noisy again as the engine comes to a stop.
This morning I started it up and again the noise was there for maybe 3 mins but as the engine heats up the noise disappears. All good until you turn it off and it briefly comes back before it stops.
So, has the dynamo bearing been overstressed as I fear and the heat' s just playing tricks or is there something else I've overlooked?
You thoughts as ever are much appreciated.
Ozza
Ozza
