Giardiniera1969
- Mar 9, 2014
- 125
- 40
Spring is back and with it Fiat Cable Blues. I had a new issue today with the throttle control cable. I gave it gas and felt a pop and the pedal became loose. I opened the tunnel and found my throttle control cable had snapped. The guy who rebuilt this car seemed to use some weird clamp to clamp the cable through one of the holes in the gas pedal. I don't think that it is correct but not too sure. I ordered a new cable today but not really too sure how it goes on. It looks like it has a grommet over the gas pedal end which makes sense vs just a piece of wire and clamp. I looked at the other posts and the pictures showed the right hand drive version. Any advice would be appreciated.
Also, I when I took off the front tunnel, I found what looks like a speedometer cable not attached to anything although my speedometer works. Seems to have the back unattached in the engine compartment as well
The first pictures are of the throttle wire and clamp, and the next ones are of the mystery cable front and rear.
