Giardiniera1969
- Mar 9, 2014
- 125
- 40
My little Fiat has to idle for about 5 min before I can drive it. If I start giving it gas while the engine is cold (mash the gas pedal), it sputters and dies. If I feather the gas pedal, I can slowly get the engine speed up and start going if I need to.
A big problem is that if I don't idle it, I can't get out of the garage due to it being underground and there is a steep ramp to go out. Sometimes, I have to make a couple of runs at the ramp to get out.
Once the car warms up, it does not seem to have the problem, but if you stomp the gas pedal (like when the light turns green), it still hesitates just a bit like it is going to die, so you kind of have to ease the gas pedal. A technique I use is a few seconds before the light turns green, I will start easing the gas pedal then let out the clutch when the light turns.
Anyway, after saying all of that how can I fix it? Does this happen to others as well?
