124spiderman
Member
There's probably a post on this somewhere but I thought I might "cast the net" to see what I get so to speak...
My 500 (650cc conversion) won't start when the engine is hot. Checked spark ok, smells of fuel if I keep cranking. Starts great when cold, idles fine.
But after a long drive, I stalled it at a set of traffic lights and it wouldn't start. If I wait 5-10 mins or so it will fire up. Checked the compression all good. Not running points or condensor, as I have a hall-effect Hot-Spark ignition points conversion. So should be better and reliable.
I'm going to check the valve clearances next, then replace the coil. Does anyone have any suggestions that I may have missed....?
Heat soak? Vapour lock as I'm running 98 octane., but I can clearly smell fuel if I keep it cranking.
