Technical FIat 500 F 1969 remove dashboard
Dryblas
Hello,
I must changing bulb on the dashboard in my Luigi.
Can anyone advise me (best option fotos) how remove dashboard.
Hi does it have the round speedo for a 1969 car I assume it does? If so you don't need to take the dash out you should be able to get to them from inside the bonnet behind the fuel tank. They just pullout from the back of the speedo.
Tony
Tony
Hello I got rectangular daschboard
Behind fule tank I see only plug control lamps (2 pcs) dont se nay mount bulbs.
yes i have fuel gauge.
Look exactly like this one
hello,
Anyone have idea like remove this dashboard.?
I do not want anything to break during removal
I think you will find that there are metal spring clips holding in the instrument panel. They need to be released from the bonnet side by prising them with a screwdriver. You may have to remove the fuel tank to get access.
Hello,
I find method, under plastic cover speedometer there are 2 clips, I must push and release speedometer frame. Before unplug the speedometer cable and plug.
Unfortunately after remove speedometer I discovered that I have revised dashboard. Now its ver 500 L with rectangular speedometr.
The previous owner had cut a hole for larger speedometer :(, changing stering whell. We want rebulit our 'Luigi" to full oryginal We looking for speedometr to 500F, white stering whell and inner metal dashboard LHD panel like pictures.
I don't find this element on many e-shops :(. Thx for any news about this parts.
Hi Dryblas;
Did you get my e-mail re your enquiry about my speedo head for a LHD 500F?---come back to me directly and I will e-mail some pictures to you
